It is currently Thu Dec 04, 2025 4:38 am
 Post subject: VRM Location
PostPosted: Tue Jan 17, 2012 5:44 pm
Is it possible to mount the VRM next to one of the tubes hidden by the back panel so that I do not have to have it take the place of my power or standby switch and can still set it and forget it unless I really need it?
Thanks, Joe
This is also my first post and will hopefully be ordering my tweed kit here as soon as taxes come back.
 Post subject: Re: VRM Location
PostPosted: Wed Jan 18, 2012 1:16 pm
Shouldn't be a problem, just make sure the Mosfet has a good heat sink connection,and keep your wiring good,clean and short.
Welcome BTW!
PostPosted: Wed Jan 18, 2012 8:27 pm
Thanks for the info I am thinking I am not going to use the VRM though as I want the original circuit as close to spec as possible.
Thanks, Joe
PostPosted: Thu Jan 19, 2012 12:57 pm
With VRM on max, it is the original circuit (less 3 volts on B+ only)
You can wire as suggested. Important to locate it where wire runs are short though.
PostPosted: Fri Jan 20, 2012 11:07 am
Okay thanks for the info I am really looking forward to getting taxes back soon so I can order up my kit!
PostPosted: Sat Jan 28, 2012 5:39 pm
Say I was to leave the standby in, and but the VRM in at the Power Switch on a push pull pot. How would one go about hooking this up?
