It is currently Fri Jun 19, 2026 10:04 pm
Post new topic Reply to topic  [ 34 posts ]  Go to page 1, 2  Next
 Post subject: Build Begins
PostPosted: Fri Jan 13, 2012 8:20 pm
My Triwatt kit arrived today, I'm thrilled to say the least. All parts are present and accounted for (apparently a 1uF cap was substituted for the 2uF, not a problem). I think I'll spend the rest of the evening studying the layout, schematic and build notes before I get started tomorrow.
Thanks Stephen, I know this is going to be good.
 Post subject: Re: Build Begins
PostPosted: Sat Jan 14, 2012 3:11 pm
Way to go Koop!Take your time and make sure you lead dress is clean like a Hiwatt!!!! :P There is a ton of gain to control,so clean wiring is more crucial in a Triwatt. Have fun!
PostPosted: Sat Jan 14, 2012 7:02 pm
A few pics as I begin. Sorry for the poor lighting, I loaned my lights (AB400) out to a guy and need to get them back!
PostPosted: Sun Jan 15, 2012 11:06 am
Congratulations koop! FYI you may find these build pictures useful to refer to, of one of my early Triwatt builds, which went to Malcolm Tan in Singapore.
viewtopic.php?f=14&t=1647
Also the gut shot from the Triwatt I built for bgroup - viewtopic.php?f=14&t=2156 I used a slightly different approach with this one, mainly for cosmetic reasons, so I had to use more shielded wire due to not keeping the longer wires quite so close to the chassis.
PostPosted: Sun Jan 15, 2012 12:41 pm
Great, thanks for the links! Photos don't show for me in the first thread though.
PostPosted: Mon Jan 16, 2012 11:05 pm
OK, a couple of pictures. I found my trusty Canon 500EX flash and managed a couple of shots before the batteries went TU. I'll get more batteries or even better, get my Alien Bees lights back. I know, the first shot (under exposed) looks like a spaghetti mess but it's OK, I know where I'm going (at least I think I do). This amp carries some serious iron!
PostPosted: Tue Jan 17, 2012 12:04 am
That's so weird. They don't show for me either. I'll have to get this looked into. Those pictures should definitely be right there.
PostPosted: Tue Jan 17, 2012 1:18 pm
Casualty of a hacker clean-up 2 months ago. We will try to recover them. :oops:
PostPosted: Thu Jan 19, 2012 1:13 pm
I hope these help. Probably needs some editing, but here you go!
viewtopic.php?f=14&t=3135
PostPosted: Sat Jan 21, 2012 11:04 pm
Success!!! I powered it up today. :thumbsup:
Had one mistake that was apparent when I checked voltages. Took me a while to track it down, I had the jumper lead from the 16uF positive end to the wrong turret - it was on the 1K resistor instead of the 220K. If I hadn't put the jumpers on top of the board it would've taken a bit longer to track down. Sometimes I get so engrossed in building I don't want to stop. In this case it means I didn't take photos along the way. Oh well, there's plenty of good looking build photos available.
Played a while tonight, it sounds great. Very little noise unless I have the boost up around 11 o'clock - it starts to hum a bit from there. I'll need some time to tweak settings before I decide if it dethrones the 18 Watt sIII as my number one.
PostPosted: Sun Jan 22, 2012 12:07 pm
A few pictures:
PostPosted: Sun Jan 22, 2012 12:11 pm
Another front shot.
PostPosted: Sun Jan 29, 2012 12:27 am
FedEx dropped off an Avatar G212 Vintage cabinet loaded with Hellatone 30 and 60 speakers today. The Triwatt through this cabinet is awesome. The efficiency of these speakers makes for a loud rig! The sound is sweet, I'm already thinking about building another for a friend that gigs four nights a week.
PostPosted: Tue Jan 31, 2012 1:15 am
Congratulations!!!
Ideally, for this kind of amp you need some kind of Fane clone speakers, such as BBQ FC12s or Eminence Tonker Lites.
PostPosted: Fri Mar 09, 2012 9:05 pm
The head cabinet arrived today - beautiful workmanship. I used foil tape to shield the bottom of the cab, this resulted in the bright input shorting. It was a quick fix and now it sounds even better than ever. Can a beautiful home for the chassis enhance the sound (I don't think the foil tape did anything useful)?
PostPosted: Sat Mar 10, 2012 4:24 pm
Heh Koop!
Where'd you find the foil tape?
Stew
PostPosted: Mon Mar 12, 2012 8:51 am
I got the tape at Home Depot. Most hardware stores should have it - it's used for stove pipes or heater ducting.
PostPosted: Mon Mar 12, 2012 11:34 am
OH is that the aluminum stuff that comes in rolls about 5" wide?. If so.. how did you make electrical connections between the strips and to chassis?
Stew
PostPosted: Tue Mar 13, 2012 8:21 pm
It's less than 5" wide, more like 3". The chassis rests on it, so I'm relying on that for the connection, in essence it becomes an extension of the chassis. I may not have that right, I don't know. I'm not sure how effective my attempt at shielding is.
I have to say, my number 1 go to rig is now my Gibson CS Les Paul G0 and the Triwatt!
PostPosted: Wed Mar 14, 2012 12:29 am
I think that should be quite effective. If you're worried at all, just use some steel wool to rough up the points on the metal tape where the chassis rests.
