It is currently Thu Apr 16, 2026 3:53 pm
 Post subject: First Build - Tramp Head
PostPosted: Sat Feb 21, 2015 12:40 am
Hi all, Just finished my first build. Will check it over again in the morning before firing (hopefully no pun) it up. I've posted some pictures below if anyone would be kind enough to give it a once over with a different set of eyes. Note, the 220k across the 50u filter caps are on the underside.Thanks,
Mike
PostPosted: Sat Feb 21, 2015 3:42 am
Having just finished mine, I feel a special kinship here:
You did such a phenomenal wiring job that I don't believe you it's your first ;)
I did take a hard look and I honestly can't see any errors assuming you've checked all the flying leads below board.
Good luck! It's a great sounding amp.
PostPosted: Sat Feb 21, 2015 10:38 am
Looks good from a quick scan. Might want to shorten that loopy NFB wire though.
PostPosted: Sat Feb 21, 2015 3:50 pm
:thumbsup:
Looks good from here too.
PostPosted: Sat Feb 21, 2015 7:05 pm
I will probably shorten the NFB wire. I left it long because I was considering swapping it for a different white wire that was shorter than I had liked to make it look neat (my OCD). I'll let you know how it goes. Thanks for looking!
PostPosted: Sat Feb 21, 2015 8:56 pm
So I powered it on. Was checking voltage (120 at the wall) so voltages were a little high but all seemed fine until I checked heater voltages at the tube sockets. Had ~6.5V on the terminal strip and across the LED/R24 (3 and a bit to ground). I noticed the black lead on the terminal strip for the heater wire going to each socket was poorly soldered (didn't fill the whole void with solder). I re-soldered it. Hear is the kicker. The fuse blew when I turned it back on. I rung everything out before but I guess there is something wrong with the heater circuit? Any ideas? I have a couple of 1A fast blow but not any 1A slow blow.
PostPosted: Sat Feb 21, 2015 11:00 pm
You saying the fuse blew when you had a fast blo in?
You need a slo-blo. The fuse will always blow if you use a fast type fuse.
PostPosted: Sun Feb 22, 2015 10:08 am
no, the slow blow fuse blew. Now I only have fast blow fuses remaining. I checked Canadian Tire and they didn't have any 1 A slow blow. The Source only has the smaller ones (5mm/20mm) on their website. Not aware of any electronics stores around Ajax. I think it will have to wait until Monday maybe.
PostPosted: Sun Feb 22, 2015 11:20 am
Closest I can think of is Creatron Electronics at Victoria Park and Sheppard. Think they are closed Sunday though.
PostPosted: Mon Feb 23, 2015 6:46 pm
Lovely looking build mgp. The great thing about the Head version is the smorgasbord of cabs/speakers, available, so many choices that can give the amp a whole new voice. What cab/speaker will you run her through? :thumbsup:
