It is currently Thu Apr 16, 2026 12:32 pm
Post new topic Reply to topic  [ 72 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Thu Aug 27, 2015 6:08 pm
Here are the measurements with tubes in.
VRM idle VRM max
Cap 1 2.6 47
Cap 2 462 456
29 .169 2.89
340 2.4 42.5
191 1.9 30.3
203 2.2 34.8
Main voltage at fuse holder: 64
Heater voltages
Power tube: pin 2&7 : 3.5
Preamp tube: pin 4&9 : 3.5
PostPosted: Thu Aug 27, 2015 7:12 pm
If your main voltage is only 64, that's the first place to start. It should be 120V, same as at the wall.
PostPosted: Thu Aug 27, 2015 7:22 pm
Is it possible I can still have a grounding issue?
Well, at this point I think I'll be taking out the board so I can also check the bottom and spend more time cleaning up the solder joints and making sure all the right connections are in place.
Thanks again for the help Andrew.
PostPosted: Thu Aug 27, 2015 7:25 pm
I'm assuming you are in North America....
If it were me - and again I am Really not very knowledgeable - I'd probably spend some time getting the main voltage where it needs to be before taking anything apart.
PostPosted: Thu Aug 27, 2015 9:35 pm
Micheal, is your meter working properly?
Did you have it set for AC volts when you checked the line voltage at the fuse holder?
What does your meter read if you set it for AC volts and measure across the black and white wires on the power cord?
What does it read if you (carefully) plug the probes directly into the wall socket that powers the amp?
PostPosted: Fri Aug 28, 2015 9:51 pm
Thanks Mitch, I'll be away this weekend and will try that
Andrew, I live in Ottawa.
PostPosted: Sun Aug 30, 2015 12:41 pm
Good advice. The outlet could be miswired as well. Check that too.
PostPosted: Mon Aug 31, 2015 5:58 pm
Yes
123.4V
123.4V
PostPosted: Mon Aug 31, 2015 6:06 pm
Is that 64V voltage coming 'out' or going 'in' to the fuse holder? Very strange, as everything is half the line voltage.
PostPosted: Mon Aug 31, 2015 7:32 pm
it's 64V for both. This is with the black to chassis and the red at the 'in' or 'out'.
PostPosted: Mon Aug 31, 2015 8:31 pm
Can you post a good picture of your power side wiring?
PostPosted: Mon Aug 31, 2015 10:03 pm
Thanks for taking a look Stephen.
PostPosted: Mon Aug 31, 2015 10:33 pm
in picture 3, showing the connections to the power switch, is there 124V between the switch terminal and the 3-lug terminal strip? there should be.
PostPosted: Tue Sep 01, 2015 6:00 pm
Yes, it's 124V from the switch terminal to the 3-lug strip.
PostPosted: Tue Sep 01, 2015 8:24 pm
And what is coming out is half what was expected. If you are getting only half of the expected voltage out, It seems like the Wires to the transformer are labelled wrong. From the picture you posted, they look correctly connected according to the wiring diagram and layout.
PostPosted: Tue Sep 01, 2015 9:27 pm
What are my options? Reverse the wiring from the transformer?
PostPosted: Wed Sep 02, 2015 12:21 am
Looking at your first post, it looks like you have a high enough B+. I was thinking it was half because your heater voltage was half. Is your heater voltage, in AC volts, 3.2 across the heater or 3.2 from each pin to ground, totalling 6.4 VAC?
In summary, what is your B+ on max and what are your heater voltages.
Thransformer wiring may not be the issue!
PostPosted: Wed Sep 02, 2015 5:45 pm
Meter set to AC
Measurement - pin to ground
Power tube: pin 2&7: 3.5 AC
Preamp tube: pin 4&9 : 3.5 AC
Measurement - pin to pin
Power tube: pin 2 to 7: 7.0 AC
Preamp tube: pin 4 to 9: 7.0 AC
B+
-----------------VRM idle----VRM max
1st 50uf cap:-----2.6----------47
2nd 50uf cap:-----462--------456
To supplement my lack of knowledge with measuring, I'm having a friend over Friday after work that has a background in hardware/meters/circuit boards, so he should be able to help figure this out. I've promised beer after it works.
Again, I appreciate it all the help.
Michael
PostPosted: Wed Sep 02, 2015 8:10 pm
Interested to know how it works out! Beer should get the job done.
In the meantime, trace out all your circuits, comparing to the schematic. Make sure everything is where it is supposed to be.
PostPosted: Wed Sep 02, 2015 11:24 pm
mmcginn wrote:
B+
G'day Michael,
Probably stating the obvious but those VRM voltages look very weird to me (also, for clarification are you calling C12 "1st"?. Just pointing this out because the "first" cap is actually the second cap in from the end of the board (C13) which is connected directly to rectifier diodes, hence "first").
It's hard to tell from the pics where the connections go as they seem to be under the board but it might be worth double checking the VRM control pot to board connections for correct point to point routing and also soldering/connection quality.
For example, on an amp with tubes in and speaker connected, I'd expect readings more like:
VRM B+ measured at positive side of C12 =
Position Idle = 40 VDC
Position MAX = 427 VDC
