It is currently Mon Jan 19, 2026 2:40 pm
PostPosted: Wed Oct 19, 2011 3:17 pm
Can i put the TC-15 gain switch on a foot-switch instead of the DPDT switch. I'd like to just have an input jack there instead of a switch. Has this been done?
PostPosted: Wed Oct 19, 2011 3:25 pm
Connect the two leads going to the switch to the tip (hot) and sleeve (common) of a jack. To make it simple use an insulated jack.
Then just use a footswitch that shorts the two terminals together, a SPST will do.
PostPosted: Wed Oct 19, 2011 4:15 pm
That's great. thanks very much.
Could i change anything in that circuit to get more gain out when i stomp on the pedal?
PostPosted: Thu Oct 20, 2011 9:01 pm
Do you think it would pop when activated?
PostPosted: Thu Oct 20, 2011 10:19 pm
I wouldn't think so because the cap is not being charge when the boost is not engaged. The cap's - is at 0V (ground) and the + is hanging with nothing to charge it.
I dunno if the sudden current in rush would make it pop. Maybe try a large resistor in parallel (>1M).
echidna does it pop if you've tried it yet?
I've done this before but forget the results... :damntech:
PostPosted: Fri Oct 21, 2011 2:31 am
Not done it yet but plan to this morning. Will let you know. If it ford I'll put in the 1m resistor. Thanks.
PostPosted: Tue Apr 30, 2013 11:13 am
hey guys,
i've done the footswitchable "boost"...and it pops!
i think i should put a 2m2 resistor on the lug to the groud to avoid the pop...is this correct?
raffa
PostPosted: Tue Apr 30, 2013 11:29 am
Put a 470K-1M resistor across the switch.
PostPosted: Tue Apr 30, 2013 11:35 am
thanks...
raffa
PostPosted: Thu May 02, 2013 10:31 am
..and please let us know how it works for you.
PostPosted: Thu May 02, 2013 11:17 am
yes, will do...i'm waiting for my stuff....unbelievable delivery delays here in europe...:-9
PostPosted: Tue Apr 26, 2016 2:39 am
did this all work out ?
PostPosted: Tue Apr 26, 2016 3:17 am
Yes it did! put a shunt resistor 2.2M to ground --> across switch.
rafa
PostPosted: Sat Nov 26, 2016 10:01 pm
Just wondering what the consensus is on this mod - a good one? I really like the sound of the boost and recently had to replace my switch (broke the bat in transit) and so it got me thinking of footswitch. What kind of cable for the SPST? Also about the resistor - you solder this between the two lugs of the footswitch jack?
2x6L6
PostPosted: Sat Dec 03, 2016 12:30 pm
2x6L6
Connect the jack on the amp to the footswitch with a regular guitar cable. The footswitch is just a SPST switch that shorts the tip (hot) and sleeve (ground) of the cable together.
Yes solder the resistor across the footswitch jack in the amp.
PostPosted: Sat Dec 03, 2016 6:11 pm
2x6L6
Thank you so much! Very helpful.
PostPosted: Mon Dec 05, 2016 12:48 am
Don't know if this is any use but I built a simple footswitch with LED to use with the boost on my Unleash, it just uses a spare guitar lead,so I think it would work in this application too. The LED only uses the battery (lasts forever, mine still works after a few years!) when the boost is switched in.
http://forums.fender.com/viewtopic.php? ... 7#p1085847
PostPosted: Mon Dec 05, 2016 1:19 am
Sweet! Great reference.
I spent a bunch of time with my TC15 today specifically to decide if I wanted to do this mod or not. What I decided for now is that I'm leaving the switch as-is, but am leaving it in the ON/boosted position. Previously I had felt it was a bit too hot for my tastes but critically listening and playing today, came away feeling that the boosted sound is fatter and juicier than not, and it also brings the volume of the two channels closer in balance. I find the EF86 channel is a bit louder otherwise, which is easily adjusted using the channel volumes, but this makes it even simpler. Looking forward to making sure clean headroom is sufficient for stage use but I'm guessing it is. Glad to have all this info should I change my mind - especially now that I have all the parts.
PostPosted: Tue Oct 24, 2017 4:46 pm
ทางบ้าน
