It is currently Sat Apr 05, 2025 11:26 am
Post new topic Reply to topic  [ 42 posts ]  Go to page 1, 2, 3  Next
 Post subject: sIII with 6v6s
PostPosted: Thu Jun 08, 2006 12:26 pm
Stephen, correct me if I'm wrong, but were you experimenting with 6v6s for an S111? Seems I remember a comment on one of these threads some time ago. If yes, will it be offered as a kit?
Btw any sign of an ampfest in Toronto?
Thanks Jim
PostPosted: Thu Jun 08, 2006 10:49 pm
jmiata.
Yes, a 6V6 sIII has surely crossed my mind more than twice. Our new design head chassis has extra holes punched so a 6V6 sIII is in the cards!
 Post subject: S111 with 6v6s
PostPosted: Fri Jun 09, 2006 7:02 am
Stephen, let me know when this kit is ready. Since I have 2 el84s and 1 6L6 amp I would like a 6v6. Still love the 18 watt tremelo!
Any word on a Toronto ampfest?
Jim
PostPosted: Fri Jun 09, 2006 11:01 am
jmiata,
Haven't had a chance to set up an ampfest here yet but would love to sponsor one. Hoping to have a 6V6 version in the near future. My next personal build in fact.
 Post subject: S111 6v6
PostPosted: Fri Jun 09, 2006 12:59 pm
Will you be selling this as a kit when you get yours finished? I just bought one of your head cabs from a chap in PEI and now it needs to be filled!
Jim
 Post subject: Re: S111 6v6
PostPosted: Fri Jun 09, 2006 8:13 pm
Jim
I guess you like purple eh Jim! :D Yeah, I probably will.
PostPosted: Fri Jun 09, 2006 8:45 pm
Yes purple is good, good enough for Marshall, good enough for me. Please keep me posted when you're ready to market this kit, I'll be buying.
Jim
PostPosted: Tue Jun 13, 2006 10:47 pm
Steve, are the extra punches for the 6v6s? Is the new head design currently shipping with the head kits? :shock:
Rick
PostPosted: Wed Jun 14, 2006 7:11 am
Yes, the new head is shipping with the kits. Note changes:
:arrow: Two extra holes for tubes (more options incl. 36W, 6V6 with minor mods);
:arrow: Can cap moved to front of chassis (cleaner wiring);
:arrow: Moved board towards input end (quiet, more direct wiring); and
:arrow: A few minor changes but No panel changes
Here's a pic.
Come to think of it, we could probably offer to punch out some holes for octals. :D
PostPosted: Mon Jun 19, 2006 12:05 pm
Coco, I am interested in the 6v6 amp. I have the sIII and was considering 6v6's, but I like the new chassis design. Couple of questions.
Can the 6v6's and el84's be used at the same time, or are they switchable? What are the options? Also, can I use the sIII board with the new chassis? I'm sure that a new ot and pt would be needed.
PostPosted: Sat Jun 24, 2006 5:32 pm
Well, we're going to play with it.
First off, 6V6 & EL84 will be either switched out/in, or just plug whichever set you want. The new chassis has extra holes for this as an option if desired.
Plan is to use the same Trannies. The new Trinity OT has a 5K tap so we'll experiment with that as an option.
Same board as well.
PostPosted: Wed Aug 02, 2006 12:35 am
Anything new on a 6v6 loaded sIII? I'm waiting patiently. :D
PostPosted: Wed Aug 02, 2006 7:05 am
It will be our next build. The new Trinity tranny is being tested with some 6V6. Looks like it will be a good combination.
I'm still testing it in the 6V6 and letting it break in, but it sounds great here too. I really gets the proportion of highs to lows of a bigger amp, like a 50 watter. The low end doesn't get flabby like in a lot of small amps. rjgtr
PostPosted: Sat Aug 05, 2006 11:05 am
Stephen,
Let us know how it goes. I want to convert my JA TMB to an sIII with 6v6's. Have you got a prelim schematic I can look at? :-).
Bob
PostPosted: Sat Aug 05, 2006 11:12 am
No schematic until we'be built and tested the first one. BTW rjgtr says the new trannies are great with 6V6s.
I'm still testing it in the 6V6 and letting it break in, but it sounds great here too. rjgtr
PostPosted: Sat Aug 05, 2006 11:46 am
Can I use my existing 18watt OT?
PostPosted: Sat Aug 05, 2006 12:21 pm
You can try it 8K impedance should work. The Trinity has a 5K tap that could be used as well.
PostPosted: Sun Aug 13, 2006 12:43 am
Being a new guy here I'm interested in how you will switch between the two power sections. Also, don't leave us combo guys out. I'm thinking of adding a preamp tube hole, moving all the tubes down one hole, putting the big cap on the top and open the last two holes for the octal sockets.
PostPosted: Sun Aug 13, 2006 7:48 am
To start, would just replace the power tubes when I wanted V6 power. But it will become a switch at some point in time I imagine if it sounds great. The new combo chassis we have designed, did move the cap to the top and added 1 extra hole. [we also added an impedance switch]. You could make it work in the new chassis by replacing the impedance switch hole with an octal hole. Of course, you can permanently switch from EL84s, but I wouldn't advise that.
I just punched out the octal holes in one of the new head chassis. This will be the protoype.
PostPosted: Sun Aug 20, 2006 9:36 am
Ok, I hve a project on the bench and here is where I'm starting.
Reduce the PI tail resistor (R12) from 56K down to about 27k;
Change the 6V6 cathode resistor (R20) from 120 ohms to 250 ohms 5W;
Leave bypass cap as it is; and
Use individual screen resistors (R23 X 2) of 470 ohms, 2W each.
I can't help out too much until I've had a chance to test this. Let us know if you try it & how it works.
I'll report back on my progress.
Users browsing this forum: Google [Bot] and 12 guests
